fxv300
Sep 04, 2021Aspirant
Macbook Pro cannot connect to RAX20
Macbook pro cannot connect to Netgear router. Macbook Pro cannot connect to RAX20 (about 1 meter away from router), cannot see two SSIDs. The same Macbook can connect to a Netgear WAC124 setup as a...
BadMoodDude
Nov 06, 2021Aspirant
Not that I know the answer, but there some basic unanswered questions...
So you unplugged everything and let it sit unplugged for above 5 minutes?
After restarting the RAX20, do the appropriate lights on router turn on/blinking?
Are the antenna still connected tightly?
Access denied via web or phone app?
Do SSIDs still work, regardless if displayed?
MacbookPro able to connect to a different router or just your Netgear?
> I had a similar issue with an iMac a couple of months ago....I gave up on that one and no longer have the iMac.
> When I do a network scan it does not show any SSID from the RAX20. Google shows many similar issues with apple devices.
If you give up on the MBP, can I have it? :)
