fxv300
Sep 04, 2021Aspirant
Macbook Pro cannot connect to RAX20
Macbook pro cannot connect to Netgear router. Macbook Pro cannot connect to RAX20 (about 1 meter away from router), cannot see two SSIDs. The same Macbook can connect to a Netgear WAC124 setup as a...
Nov 06, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
The same Macbook can connect to a Netgear WAC124 setup as an Access point.
Also same device can connect to a TP-Link Access point.
Just updated router to new firmware Firmware Version V1.0.3.96_2.0.59
I had a similar issue with an iMac a couple of months ago....I gave up on that one and no longer have the iMac.
When I do a network scan it does not show any SSID from the RAX20. Google shows many similar issues with apple devices.
Any help with this appreciated.
Many Thanks
Frank
- BadMoodDudeNov 06, 2021Aspirant
My apologies for replying to Frank's message in situ. But the original post had no air
of being router-specific, and my reply had only basic questions someone else would
need to ask as well in order to cut down on "playing the guessing game". Although IMO,
it seems wrongheaded somehow to go down such a specific path (i.e., your first link)
for something that appeared to be neither WiFi 6 nor hardware-related.
Thanks for the second link though.
- fxv300Nov 07, 2021Aspirant
Had a firmware update yesterday....device can now see all the SSIDs and can join....so the firmware fixed it I guess.
- FURRYe38Nov 07, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
