fxv300
Sep 04, 2021Aspirant
Macbook Pro cannot connect to RAX20
Macbook pro cannot connect to Netgear router. Macbook Pro cannot connect to RAX20 (about 1 meter away from router), cannot see two SSIDs. The same Macbook can connect to a Netgear WAC124 setup as a...
BadMoodDude
Nov 06, 2021Aspirant
My apologies for replying to Frank's message in situ. But the original post had no air
of being router-specific, and my reply had only basic questions someone else would
need to ask as well in order to cut down on "playing the guessing game". Although IMO,
it seems wrongheaded somehow to go down such a specific path (i.e., your first link)
for something that appeared to be neither WiFi 6 nor hardware-related.
Thanks for the second link though.
fxv300
Nov 07, 2021Aspirant
Had a firmware update yesterday....device can now see all the SSIDs and can join....so the firmware fixed it I guess.
- FURRYe38Nov 07, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
