fxv300
Sep 04, 2021Aspirant
Macbook Pro cannot connect to RAX20
Macbook pro cannot connect to Netgear router. Macbook Pro cannot connect to RAX20 (about 1 meter away from router), cannot see two SSIDs. The same Macbook can connect to a Netgear WAC124 setup as a...
fxv300
Nov 07, 2021Aspirant
Had a firmware update yesterday....device can now see all the SSIDs and can join....so the firmware fixed it I guess.
Nov 07, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
