SJIrish54
Apr 30, 2022Tutor
Macbook Pro not connecting to 5G on R6700v3 — Nighthawk AC1750 Smart WiFi Dual Band Gigabit Router
I've tried changing channels with no impact. Using the channel that Mac WIFI Diagnostics scan recommends. Nothing seems to help. I'm only a few feet away from the router and in the same room. ...
Apr 30, 2022Guru - Experienced User
If everything but the one device connect, what makes you think its the router causing the issue?
I would go into the mac and clear out any retained network settings and see if that helps
SJIrish54
May 01, 2022Tutor
Totally see it as a Mac issue and not a router issue. Was not implying otherwise. Mentioned the firmware update just to eliminate that as a possible suggestion for resolution. Will try the suggested clearing process next opportunity I get.
