SJIrish54
Apr 30, 2022Tutor
Macbook Pro not connecting to 5G on R6700v3 — Nighthawk AC1750 Smart WiFi Dual Band Gigabit Router
I've tried changing channels with no impact. Using the channel that Mac WIFI Diagnostics scan recommends. Nothing seems to help. I'm only a few feet away from the router and in the same room. ...
SJIrish54
May 02, 2022Tutor
I'm traveling at the moment and can't try those things but will at my earliest opportunity. I do have a second location I work out of that only has 5G frequency activated. I am able to connect fine. The challenge is, there are some devices that only support 2.4G frequency. Thanks.
ArdithPBrown
May 02, 2022Aspirant
I'm also facing same issue, R6700v3 is not connecting on my laptop. It keeps disconnecting again and again.
