pdgraham940
Mar 17, 2022Aspirant
MacBook Pro says I'm connected to the internet and lists an IP address, but No Internet Connection.
Firmware V1.0.4.76_10.1.82 just installed with Nighthawk app. The status bar on my MacBook Pro shows a strong signal. The Network Preferences says "Wi-Fi is connected to NETGEAR35-5G-1 and has the I...
Mar 18, 2022Guru - Experienced User
1. what modem/gateway is the router connected to?
2. does it do it for all the bands?
3. is any other device having issues or just the mac book?
- pdgraham940Mar 18, 2022Aspirant
I'm away from the wifi site so....
1. Modem was supplied by Hughes Net.
2. It occurs on all bands.
3. It occurs on all devices.
- plemansMar 19, 2022Guru - Experienced User
Hughes net supplies gateways with their own integrated routers. It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions. Not sure if the hughes net gateway supports this.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
