RoastBeefy's avatar
RoastBeefy
Manual Adding New Devices Under Access Control
Any help is appreciated!   When I have access control on and "Block new devices from connecting" selected, I am unable to manually allow new devices. Once the screen refreshes the device is still b...
  • RoastBeefy's avatar
    Sep 10, 2020
    I want to be sure to document this in case someone has it happen in the future.
    I posted my issues yesterday along with confirming there were no firmware updates available. I logged into my router today and saw an new firmware update available (V1.0.2.74). I don't know if it was very crazy timing, but the following has changed while having "Block all devices from connecting" in Access Control:
    1. A new device trying to connect to the router (with correct password) is now given a direct message that the router is blocking access. I did not see this before, so it really is a helpful thing to sift through possible connection problems.
    2. I am able to change a specific device from "Block" to "Allow" and have the change persist.
    Like I said, it may have simply been crazy timing, but my issue is completely resolved now.
