perseid
Feb 10, 2019Aspirant
Manual Configuration as Access Point R7800 X4S AC2600
Hi, I own the R7800 Nighthawk X4S AC2600 Wifi Router. I always had it setup as Access Point with a fixed IP in my LAN (192.168.0.2) connected with network cable to my main TPLink wired router which a...
- Feb 10, 2019
Consider letting the AP get an ip address automatically -- and then in your main router, add the MAC address of the AP as a reserved ip address.
duckware
Feb 10, 2019Prodigy
perseid
Feb 11, 2019Aspirant
Thanks, both suggestions worked, for now I chose to set the AP in automatic and let the main router assign the reserved address, but ultimately I think I will go for assigning the IP manually , maybe it's cleaner to have each device set independently rather than have the main router administer everything
