Lartigue
Aug 27, 2021Aspirant
manual eax80 french
Hi, Where can i find a french pdf manual for may EAX80 ? best regards. Lartigue
- Aug 27, 2021
https://www.netgear.com/support/product/eax80.aspx
click on top right corner drop down and select french as language.
Not sure if that'll do it.
Aug 27, 2021Guru - Experienced User
Lartigue
Thanks you for your answer, anyway still in english...
