jeamorgan
Jul 04, 2017Aspirant
Manually Setting Time on R7000
I recently changed ISPs and now my router time keeps getting reset to a date/time that is years off. I have done some reading on this and it sounds like my new ISP does not support NTP(?) or whateve...
- Jul 04, 2017
Not in stock software... But.. What ISP modem are you using? Is it a modem only, or a router / modem combo? If it's a combo, bridge it, and see if that fixes your problem..
EDIT: Not sure what version of firmware you are running, but this version fixes an NTP issue: https://kb.netgear.com/30955/R7000-Firmware-Version-1-0-7-2
When you upgrade the router's firmware, reset the router to factory default and reconfigure..
netwrks
Jul 04, 2017Master
