GT-Force
Jan 03, 2021Aspirant
Maximum speed is limited on R8000. What parameters may cause this?
Hi, My router was working at its top speed (1000 Mbps) until we moved. Now, although the ISP speed is still 1000 Mbps (fiber), I am getting ~250 Mbps maximum. Frankly, if I reset the router t...
No1Mportnt
Jan 03, 2021Luminary
Have you tried testing it from the modem to see if you are getting full speed there?
- GT-ForceJan 03, 2021Aspirant
Thanks for the reply, but as I mentioned, I was getting the full speeds from this router after doing a factory-reset, indicating that the ISP speed was not the issue.
