GT-Force
Jan 03, 2021Aspirant
Maximum speed is limited on R8000. What parameters may cause this?
Hi, My router was working at its top speed (1000 Mbps) until we moved. Now, although the ISP speed is still 1000 Mbps (fiber), I am getting ~250 Mbps maximum. Frankly, if I reset the router t...
GT-Force
Addendum:
I had limited speeds with Access Control (AC) disabled or enabled.
After I did a factory reset today and reloaded the configuration, the speed was limited with Access Control enabled.
Once I disabled the AC, the speed went back up to its max! This is puzzling, since the speed was already limited before enabling AC.
Anyway, just posting this in case this order of events may help anyone else.
Cheers.
