pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
bteeuwen
Feb 22, 2018Initiate
+100
This is extremely annoying when using the netgear vpn service.
I read "As soon as we have it working before 31 april 2018, it is ok. So that OpenVPN is not broken" at https://community.netgear.com/t5/Nighthawk-WiFi-Routers/OpenVPN-update-breaks-R7000-and-probably-other-routers-VPN/m-p/1435672/highlight/true. With the openvpn update I'd say from a user experience it is severly broken from 21st of february.
Please provide a solution as soon as possible.
