pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
pyrmont
Feb 28, 2018Guide
I'd hope Netgear is aware of this issue given it was initially reported on this forum back in June of last year. But more to the point, your users don't care whether you're 'aware' of it. What we care about is when you are going to 'fix' it.
Diggie3
Mar 01, 2018Luminary
- pyrmontMar 02, 2018Guide
Your guide worked! Thank you!
I did it on Linux and so had to do things a little differently but, as you suggested, the steps were generally the same. Thank you for taking the time to put that all together.
In case it helps others, I wrote up some instructions for Linux users on my blog.
