pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
pyrmont
Mar 02, 2018Guide
Your guide worked! Thank you!
I did it on Linux and so had to do things a little differently but, as you suggested, the steps were generally the same. Thank you for taking the time to put that all together.
In case it helps others, I wrote up some instructions for Linux users on my blog.
