pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
whataboutbob
Mar 06, 2018Aspirant
Does anyone know if Netgear is issuing a fix for this before April 2018 EOL deadline or do I need to manually upgrade my certificate?
Diggie3
Mar 06, 2018Luminary
They have claimed that they will elsewhere in the forums. Based on their ability to deliver fixes for other critical product issues, I would be skeptical.
- whataboutbobMar 06, 2018Aspirant
Fingers crossed but if they don't deliver close to the deadline, I'll install the certificate. Hopefully it doesn't get to that. Thanks for your writeup, I might have to go your route with some slight tweaks for Mac but it should be siimilar.
- pyrmontMar 06, 2018GuideFor macOS, (1) the installation of OpenVPN, Easy-RSA and telnet will be different and (2) the Easy-RSA template files will live somewhere else, but otherwise everything else should be the same.
