pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
axelsegers
Mar 19, 2018Tutor
I have the same isssue. MD5 warning when connecting to the VPN on an iOS device.
Netgear are you looking at this issue? It won't work anymore from 30th of april 2018.
- schumakuMar 19, 2018Guru - Experienced User
axelsegerswrote:I have the same isssue. MD5 warning when connecting to the VPN on an iOS device.
Current firmware version on your R8900 / Nighthawk X10?
A Netgear moderator has already answered a few replies before -> JamesGL in port #6.
- martijn76Mar 20, 2018Aspirant
Hasn't this been solved by the latest 1.0.2.46 firmware? Haven't installed it yet, but the changelog does say:
New Features and Enhancements: Supports the VPN client feature.
And this would suggest a fix in the VPN department. Don't want to install unless this is the case though, all is running well at the moment (at least until end of April haha).
- pyrmontMar 20, 2018GuideI'm not sure what this is referring to but as far as I can tell, it's only in the firmware for the R7800. The latest firmware for the R7000 at the time of writing is 1.0.9.26 and it doesn't contain this fix at all.
- JamesGLMar 29, 2018NETGEAR Employee Retired
Hi All,
Resolution will be released prior to the deadline.
