pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
axelsegers
Mar 19, 2018Tutor
I have the same isssue. MD5 warning when connecting to the VPN on an iOS device.
Netgear are you looking at this issue? It won't work anymore from 30th of april 2018.
schumaku
Mar 19, 2018Guru - Experienced User
axelsegerswrote:I have the same isssue. MD5 warning when connecting to the VPN on an iOS device.
Current firmware version on your R8900 / Nighthawk X10?
axelsegers wrote:Netgear are you looking at this issue? It won't work anymore from 30th of april 2018.
A Netgear moderator has already answered a few replies before -> JamesGL in port #6.
