pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
schumaku
Mar 19, 2018Guru - Experienced User
axelsegerswrote:I have the same isssue. MD5 warning when connecting to the VPN on an iOS device.
Current firmware version on your R8900 / Nighthawk X10?
axelsegers wrote:Netgear are you looking at this issue? It won't work anymore from 30th of april 2018.
A Netgear moderator has already answered a few replies before -> JamesGL in port #6.
martijn76
Mar 20, 2018Aspirant
Hasn't this been solved by the latest 1.0.2.46 firmware? Haven't installed it yet, but the changelog does say:
New Features and Enhancements: Supports the VPN client feature.
And this would suggest a fix in the VPN department. Don't want to install unless this is the case though, all is running well at the moment (at least until end of April haha).
