pyrmont
Feb 22, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
pyrmont
Mar 20, 2018Guide
I'm not sure what this is referring to but as far as I can tell, it's only in the firmware for the R7800. The latest firmware for the R7000 at the time of writing is 1.0.9.26 and it doesn't contain this fix at all.
martijn76
Mar 20, 2018Aspirant
Ah well, I'll flash the dang thing tonight then, and see if it'll get rid of the MD5 warning issued by OpenVPN.
