pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
whataboutbob
Mar 06, 2018Aspirant
Does anyone know if Netgear is issuing a fix for this before April 2018 EOL deadline or do I need to manually upgrade my certificate?
whataboutbob
Mar 20, 2018Aspirant
I just installed V1.0.1.44_10.0.28 for my R6900, not sure if it fixes the VPN issue, release notes said it fixes security issues, whatever that means. I'll test it later.
https://kb.netgear.com/000055156/R6900-Firmware-Version-1-0-1-44
