pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
axelsegers
Mar 19, 2018Tutor
I have the same isssue. MD5 warning when connecting to the VPN on an iOS device.
Netgear are you looking at this issue? It won't work anymore from 30th of april 2018.
JamesGL
Mar 29, 2018NETGEAR Employee Retired
Hi All,
Resolution will be released prior to the deadline.
- RepiukApr 01, 2018Tutor
Any news on this update? It's April 1st and I need VPN up and running
- schumakuApr 01, 2018Guru - Experienced UserEnd of April 2018 is the do-not-exceed date.
- axelsegersApr 01, 2018Tutor
End of april is the due date and still no solution from Netgear ;-(
