pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
Repiuk
Apr 01, 2018Tutor
I need to have a solution up and running for the next month(s). My backup plan was the VPN service in Apple's Server.app. Apple killed VPN services last week in the update of server.app.
What are the options? OpenVPN as a server exists on MacOS? OpenVPN on a raspberry PI?
Or another router? Which routers run OpenVPN?
Diggie3
Apr 01, 2018Luminary
The accepted solution for this thread links a doc you can follow on Windows to put working certificates on your router. Pyromont also wrote up some steps for Linux systems. Otherwise, yes, you would need to run an OpenVPN service yourself and open its port up on your router.
- RepiukApr 01, 2018Tutor
Aha overlooked that pdf file. I'll powerup my Windows notebook and give it a try.
- Diggie3Apr 01, 2018LuminaryFyi I'm updating the doc today because OpenVPN 2.4.5 has since been released. The short story is it should all be similar except you can skip the step to use stronger algorithms (SHA256) because in OpenVPN 2.4.5 that's the default now anyway.
- cryptokiddieApr 02, 2018Aspirant
This is brutal that users have to telnet in to manually re issue and configure it. It's such a simple dev feature --- and netgear cant fix it? For a network connectivity provider you think they would take security more seriously and upgrade the crypto from an algorithm (MD5) that was severly compromised over a half a decade ago.
What is taking so long?
- pyrmontApr 02, 2018GuideI'll be the first to criticise Netgear for how slowly they're moving but I think the difficulty, explained by Diggie3, is that the router has a very weak CPU and calculating the new cryptographic keys is computationally very difficult.
The solution we've described does the computational work on your PC which is what makes it feasible. Netgear could just send you pre-calculated keys but that'd be less secure since they'd have a copy of them and they could be intercepted in transit. - cryptokiddieApr 02, 2018Aspirant
Fair enough, appreciate the work put into the guide
- schumakuApr 03, 2018Guru - Experienced User
pyrmontwrote:
I'll be the first to criticise Netgear for how slowly they're moving but I think the difficulty, explained by Diggie3, is that the router has a very weak CPU and calculating the new cryptographic keys is computationally very difficult.Considering Netgear does maintain Netgear Genie software for Windows and macOS - integrating this process there would be a possible option. In either case, Netgear would do good migrating to EC (Elliptic Curve) for OpenVPN and https access - the CPU load would be lowered masively.
pyrmont wrote:
The solution we've described does the computational work on your PC which is what makes it feasible. Netgear could just send you pre-calculated keys but that'd be less secure since they'd have a copy of them and they could be intercepted in transit.I fear Netgear will "just" update some code and continue to integrate a certificate (with a shared private key - what a joke) signed by a trusted CA for the ubiquitous domains.
A feasible choice would be to migrate to support Let's Encrypt and it's automated RA processes.Let's see what they will implement - the next weeks will tell. None of my related emails sent to Netgear key people was answered (except by the R9000/R8900 project engineer).
