pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
Repiuk
Apr 01, 2018Tutor
Aha overlooked that pdf file. I'll powerup my Windows notebook and give it a try.
Diggie3
Apr 01, 2018Luminary
Fyi I'm updating the doc today because OpenVPN 2.4.5 has since been released. The short story is it should all be similar except you can skip the step to use stronger algorithms (SHA256) because in OpenVPN 2.4.5 that's the default now anyway.
