pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
Genesismaster
Apr 24, 2018Aspirant
It is now over two months later to provide an update to the firmware with properly formated certificates. Is the problem the CA setup on the server isn't actually able to generate new certs? There is now less than two weeks till the certificates currently in use become defunct by the clients, never mind the annoying warning sign users have had to deal with. What is the solution, and what is its timeline?
jcw265
Apr 25, 2018Tutor
The cert issue has already occured, didnt even make the end of the month. Openvpn will sit in waiting on server status. All do to cert issues that Netgear was aware of. I guess they think we should purchase a newer model with the proper certs installed. NEVER !!! from me
