pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
golf06222
Apr 30, 2018Aspirant
I will never again purchase a Netgear product... No word from Netgear for weeks leading up to today.
I called their support line and this is the "first time of being made aware of the issue". She made it sound like the router is functioning as designed and it's an issue with my iphone. The only thing they will do is replace the router (you pay shipping) which we all know is not the issue.
I'm extremely disappointed and I'm now in possession of a very expensive router that doesn't do what I purchased it to do.
- shamarinApr 30, 2018Virtuoso
For R7000 beta firmware is available to public with RSA OpenVPN support. I've checked it, OpenVPN is working now.
- brian163May 01, 2018Tutor
I successfully upgraded from 1.0.6.40_1.1.90 to hotfix 1.0.9.30_10.2.33.
Upon reboot you will see the following message and it will then obtain an updated certificate:
After this is completed you have to go to the VPN tab to download an updated configuration for your devices and install them.
- shamarinMay 02, 2018Virtuoso
Yes and it's work now.
