pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
Tyree42
Apr 30, 2018Initiate
I don't have time or capacity to beta test properly (router is in US, I'm in Taiwan currently). But for those wanting the solution, it's listed in the downloads under hotfix (beta):
https://kb.netgear.com/000057097/R7000-Firmware-Version-1-0-9-30-Hot-Fix
- tonyGasproMay 03, 2018Guide
Anyone know if this hotfix works with the entire R7XXX series, or is this for a specific R7000 model router?
Thanks
