pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
shamarin
Apr 30, 2018Virtuoso
For R7000 beta firmware is available to public with RSA OpenVPN support. I've checked it, OpenVPN is working now.
brian163
May 01, 2018Tutor
I successfully upgraded from 1.0.6.40_1.1.90 to hotfix 1.0.9.30_10.2.33.
Upon reboot you will see the following message and it will then obtain an updated certificate:
After this is completed you have to go to the VPN tab to download an updated configuration for your devices and install them.
- shamarinMay 02, 2018Virtuoso
Yes and it's work now.
- spopielaMay 03, 2018Guide
Thank You, Netgear. It seems to run OK with windows and IOS clients.Too bad that we anxiously waited with no insight into the coming update. I'm not a VPN expert to critique the update details.
- schmegsMay 03, 2018Aspirant
Does the hotfix firmware work for the R6700v2, or is it only for the R7000?
