pyrmont
Feb 22, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
JamesGL
May 23, 2018NETGEAR Employee Retired
Hi All,
There are new firmwares for some nighthawk models that will support the new OpenVPN certificate.
R7000: https://kb.netgear.com/000057097/R7000-Firmware-Version-1-0-9-30-Hot-Fix
R7000P: https://kb.netgear.com/000057108/R7000P-Firmware-Version-1-3-2-34-Hot-Fix
R7900P:https://kb.netgear.com/000058266/R7900P-Firmware-Version-1-4-0-8-Hot-Fix
R8000P:https://kb.netgear.com/000058267/R8000P-Firmware-Version-1-4-0-8-Hot-Fix
R8000: https://kb.netgear.com/000058796/R8000-Firmware-Version-1-0-4-18
R9000: https://kb.netgear.com/000058270/R9000-Firmware-Version-1-0-4-2
martijn76
May 25, 2018Aspirant
Am I correct to see that R7800 now has new firmware that supports OpenVPN SHA256 cert?
https://kb.netgear.com/000058809/R7800-Firmware-Version-1-0-2-52
- McFastMay 25, 2018AspirantAlso there is new firmware for r8500 with openvpn fix 1.0.2.122
