pyrmont
Feb 22, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
mike406
Jul 12, 2018Apprentice
gramercyradio wrote:
Hi!
I installed the latest firmware for R6700 v1, downloaded and installed the scripts and files for Windows PC. Took awhile to search and understand an error: "TAP-Windows adapter 'NETGEAR-VPN' not found". The solution is to be sure to rename the Windows TAP adapter to "NETGEAR-VPN" inside Control Panel, otherwise the login will fail because OpenVPN cannot find the TAP adapter. Works great so far, glad to have the added measure of security. Will try to install the files for iOS next for iPhone X.
Open clientx.ovpn in Notepad and remove the line "dev-node NETGEAR-VPN" or comment it out by putting a semi-colon in front of it ";dev-node NETGEAR-VPN" and you won't have to name the adapter.
gramercyradio
Jul 13, 2018Tutor
Hi Mike406,
Yes! Thank you for the word of advisement, I appreciate it. I had also downloaded the client configuation and key files to iPhone X, use the latest OpenVPN app for iPhone (and accept the new configuration and key files on the app), works great on iPhone X.
Thanks!
