pyrmont
Feb 21, 2018Guide
MD5-Signed Certificate Warning with OpenVPN on iOS
As of version 1.2.8 of the OpenVPN app on iOS, OpenVPN issues the following warning: > WARN TLS: received certificate signed with MD5. > Please inform your admin to upgrade to a > stronger algori...
- Mar 01, 2018
FYI, I documented the steps to required to replace the certificates here. Unfortunately it the steps are written for users of Windows, but it also uses mostly cross-platform OpenSource tools and explains what's going on so I think it should be pretty translatable if you don't have access to any Windows boxes.
Just posting this so you have at least one go-forward path.
993TT
Jul 27, 2018Aspirant
So the R7000P had a hot fix beta firmware available 1.3.2.34, but it has been pulled when they updated the firmware to 1.3.1.44 and the 1.3.1.44 does not support SHA256, what up with that?
- schumakuJul 27, 2018Guru - Experienced User
993TT wrote:
So the R7000P had a hot fix beta firmware available 1.3.2.34, but it has been pulled when they updated the firmware to 1.3.1.44 and the 1.3.1.44 does not support SHA256, what up with that?JamesGL wrote:
Resolution will be released prior to the deadline.
So dear JamesGL, whats the deal here? Deadline passed months ago.
- 993TTJul 29, 2018Aspirant
Hah! Turns out the new R7000P firmware does have the SHA256 support. The release notes just don't mention it.
- Retired_MemberJul 29, 2018
Yes, and since they fail to mention it. People are going to wonder why their clients no longer connect to the VPN since they have to re-acqurie the new certs for each device.
