marklaz
Jul 21, 2021Initiate
Mesh extenders for R7000
Purchased this through Amazon and now want to expand the WiFi coverage. What is the best way to do it?
marklaz
Thank you! Is there a specific brand a nd model of a triband extender you would recommend? I am looking to add only one, so it sounds like my R7000 will work...
Jul 21, 2021Guru - Experienced User
The EX7500/EX7700/EX8000 are all solid devices.
I've personally used the EX8000 but its backhaul is wider than the R7000 supports.
So I'd look at the EX7500/7700
- plemansJul 21, 2021Guru - Experienced User
another option is the orbi RSB40V. It has an extender mode and sometimes goes on sale for cheaper than the other ones.
Plus it has voice built in
