Drew_K
Nov 12, 2020Aspirant
Mesh possibilities with the AC1200
Hey all, I now find myself in the need of a mesh network as I hate switching between traditional extenders. My current config CM500 Model hard wired to a Nighthawk AC1200 smart wifi route...
- Nov 13, 2020
Drew_K wrote:So in my research and thanks to you I am now drawn to 3 systems.
The Nighthawk Mesh MK62(3)
The RBK43 (seen the 3 node only for around $220)
And windering if it is really worth it to go bog and go with the RBK23 Triband for around $360.
The RBK43 is a triband and is more capable than the rbk23.
Its just a renewed version. The MK62 is fairly close prices to the rbk43 and the rbk43 will have better speeds/stability. Plus the additional satellite.
Nov 12, 2020Guru - Experienced User
How big is the home?
How many levels?
What router do you have? AC1200 is a speed not a model.
How many satellites are you looking at?
If you're looking at upgrading to mesh, I'd strongly encourage the triband mesh. its much faster, stable, and more adaptable than the dual band mesh.
For a base system, I'd look at the RBK43 system. They've been renewed lately on amazon for pretty cheap. Much cheaper than new or the newer AX systems.
And depending on what AC1200 router you have, its probably much more capable.
Drew_K
Nov 13, 2020Aspirant
How big is the home? Just under 2800 sf
How many levels? Basement and 2 levels
What router do you have? AC1200 is a speed not a model. (Sorry there) Nighthawk R6230
How many satellites are you looking at? I'm thinking 1 or 2 would do the job.
--If my internet speed coming in is pretty slow(we don't have a ton of need over work and school) is the cost increase to tri band really worth? I was looking a little at the Nighthawk Mesh devices.
--Thanks will look at them
- plemansNov 13, 2020Guru - Experienced User
1 or 2 satellites should cover that size home.
When you say nighthawk mesh device. Are you talking the line of mesh extenders or the mesh system (mk60)? Model numbers help
- Drew_KNov 13, 2020Aspirant
I was thinking the price point on the MK62 was pretty good if I only go with the router and 1 sattelite.
My two problem areas are the 2nd floor front of the house (not a big deal) and the basement can be spotty at times and my wife was asking if I could build a stand up desk over the treadmill in the basement. So the thought of getting a more consistent signal down there is really my goal.
