PhilKling
Jan 26, 2021Follower
Mesh possible with RAX50 AX5400(main) and R7000 AC1900(secondary)?
RAX50 (main) is upstairs North East Room and R7000 (secondary) is downstairs South West Room. They are wired together using cat6 through the walls. Up to date firmwares. I would like to create a s...
Jan 26, 2021Guru - Experienced User
Neither device is a mesh router.
You can set them both with the same ssid but they won't roam automatically like a mesh network. Devices will tend to be sticky and stay connected to what they originally connected to.
If you're wanting seamless roaming, the orbi line or theres a nighthawk mesh line supports this feature.
