arthurmoore
Jun 12, 2021Aspirant
Mesh System Extending Upwards
I am very happy with my mesh system by sturggling to extend upwards to the 4 floor of my home. I have the Mr60 with 2 satellies. Any reccomendation for further extending this up to my 4th fl...
arthurmoore
Think it is a fairly standard plaster board with a normal size height (sorry I can be more specific is required)
The signlal is absolutely great until the attic where it drops dramatically with the increased height of approx 3m. So thinking an extended added onto my mesh system would over come this.
Jun 12, 2021Guru - Experienced User
You can add more satellites as needed.
I just caution based on materials. things like concrete, brick, plaster lathe, foil lined insulation, metal, all do great jobs of blocking wifi and if that material is in between, sometimes the adding doesn't help.
