Rdtapt
Nov 18, 2022Aspirant
Metal pole barn
I have a metal pole barn/garage, which is only maybe 50' from my house, that I'm having trouble getting wifi into. I bought a R7000P Nighthawk to extend my coverage from my house but that didn't help...
Nov 18, 2022Guru - Experienced User
I recommend since the bar is make of metal, that you run a CAT6A STP cable from the main building out to this barn. Then connect up a router and configure it for AP mode. Then you'll get good wifi at the barn area.
- RdtaptNov 18, 2022AspirantThanks for the reply, but as stated in original post, I unfortunately do not have the option to run a wire.
- plemansNov 19, 2022Guru - Experienced User
Netgear's Airbridge is a wireless bridge setup.
You'd get 2 of them.
1 you'd mount on the house and point at the garage
the other you'd put on the garage.
The you'd use a wireless access point inside the garage to connect to the bridge on the garage.
The metal is going to block signals. So you need something to get the signal to the garage and then something in the garage to connect to that device and rebroadcast it.
- FURRYe38Nov 19, 2022Guru - Experienced User
