Rdtapt
Nov 17, 2022Aspirant
Metal pole barn
I have a metal pole barn/garage, which is only maybe 50' from my house, that I'm having trouble getting wifi into. I bought a R7000P Nighthawk to extend my coverage from my house but that didn't help...
Rdtapt
Nov 18, 2022Aspirant
Thanks for the reply, but as stated in original post, I unfortunately do not have the option to run a wire.
Nov 19, 2022Guru - Experienced User
Netgear's Airbridge is a wireless bridge setup.
You'd get 2 of them.
1 you'd mount on the house and point at the garage
the other you'd put on the garage.
The you'd use a wireless access point inside the garage to connect to the bridge on the garage.
The metal is going to block signals. So you need something to get the signal to the garage and then something in the garage to connect to that device and rebroadcast it.
- FURRYe38Nov 19, 2022Guru - Experienced User
- RdtaptNov 19, 2022AspirantThank you, that sounds simple enough! The product you mentioned is unavailable though, could you or someone else recommend a different product? Thanks again.
Might look up Air Bridge WiFi on Amazon and see whats available.
- RdtaptNov 19, 2022AspirantNot available on Amazon or anywhere else, must have been discontinued. A lot of generic bridge set ups come up on Amazon, not sure what's good and what's not. Guess I'll just have to pick one and try it. Why does this have to be so complicated? Lol
