WM21
Mar 21, 2021Aspirant
Migration from OLd Netgear WNR1000-2vcnas router to Nighthawk1900 Router
Hello I have an old NETGEAR WNR1000-2VCNAS router (about 10 yers old) and I would like to mighrate to a newer router, like the Nighthawk AC1900 router. Because of security concenrs in our area, ...
- Mar 23, 2021
> [...] seem people seem convinced that using an html front page is the
> same as using a website.That might be because it's true.
Every web site exists on a computer someplace. The management web
site for a router exists on the computer inside the router. A web site
is a web site. If you're talking to it using a web browser (and
"http[s]://"), then it's a web site. It's not complicated, but some
people seem to have enormous difficulty in grasping this (relatively
simple) concept.> To my mind web = world wide web, not something that happens on your
> local router.You can define these things any way you might wish, but that
particular definition is misleading and unhelpful.
In this case, in particular, realizing that the router's management
web site exists inside the router might help the user to understand
where the router's settings are stored.If you run a web server on a Windows computer on your desktop, is
that also not a web site because it's on your desktop, and not someplace
in the outside world?If you enable Remote Management on your router, so that it's
accessible from the outside world (on the World-Wide Web), does that
magically transform the router's management not-a-web-site into a
management web site?https://en.wikipedia.org/wiki/Pretzel_Logic
The title fits.
I've given up on trying to use logic to persuade you on this point,
but you might want to avoid trying to confuse innocent bystanders with
this kind of nonsense.
michaelkenward
Mar 22, 2021Guru - Experienced User
WM21 wrote:
My question is, if I mighrate to the Nighthawk AC1900 , would the WIreless Card List I mentioned above work with the AC1900?
I don't understand the question. What is this "WIreless Card List"?
I do know that there is no way to transfer settings from an old router to a new one. You'll have to record the existing settings and recreate them on the new router.
On which "the Nighthawk AC1900 router" does not exist.
AC1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
- antinodeMar 22, 2021Guru
Visit http://netgear.com/support , put in the relevant model number,
and look for Documentation. Get the User Manual. Read. Look for
"Wireless Card Access List". It's not complicated.> On which "the Nighthawk AC1900 router" does not exist.
Huh?
The terminology has changed since 2009. The User Manual for a newer
router might have an option like "Access Control", which seems to
resemble the old "Wireless Card Access List".> AC1900 is not a reliable guide [...]
TL;DR: "AC1900" is a speed, not a model number. Look for "Model" on
the product label (or in whatever you're reading).- WM21Mar 23, 2021Aspirant
Thank you for responding. I should have better dwefined my question; as noted this is a 10+year old router so I am probably behind in technology termonology. On my old router, you can restrict access specifically to those devices that you put on the "Wireless Card Access List" . This is done on thre router setttings page, under the advanced wireless settings option.
I am considering several NETGEAR routers, specifically the RAX45 . Specifically, would I need to create a new password and in turn create a new "Wireless Access List" ( or whaterver it is currently called ) for the new RAX45 router, or would my existing "Wireless Card Access List" under my existing password / Wireless Access List work?
I am sorry if I am not well defining the issue.
Thank you for your help.
WM21
- antinodeMar 23, 2021Guru
> [...] I am probably behind in technology termonology. [...]
Netgear changed its descriptions.
> [...]Ok. So, adapt the advice above:
"Access Control". Is that what you want?> [...] would I need to create a new password [...]
You should be able to tell the (any) new router to use the same
wireless-network SSID and password as the old router. (Regarding
"password", look for "Types of logins" in the new-router User Manual.)> [...] would my existing "Wireless Card Access List" under my existing
Your old settings are stored on your old router. The new router gets
its settings from you; it can't get its settings from your old router.
"password" has nothing to do with it. See "I do know [...]", above.If you buy a new car, how do you get your old radio presets to the
radio in the new car?
