WM21's avatar
WM21
Migration from OLd Netgear WNR1000-2vcnas router to Nighthawk1900 Router
Hello   I have an old NETGEAR WNR1000-2VCNAS router (about 10 yers old) and I would like to mighrate to a newer router, like the Nighthawk AC1900 router.  Because of security concenrs in our area, ...
  • antinode's avatar
    antinode
    Mar 23, 2021
    > [...] seem people seem convinced that using an html front page is the
    > same as using a website.
       That might be because it's true.
       Every web site exists on a computer someplace.  The management web
    site for a router exists on the computer inside the router.  A web site
    is a web site.  If you're talking to it using a web browser (and
    "http[s]://"), then it's a web site.  It's not complicated, but some
    people seem to have enormous difficulty in grasping this (relatively
    simple) concept.
    > To my mind web = world wide web, not something that happens on your
    > local router.
       You can define these things any way you might wish, but that
    particular definition is misleading and unhelpful.
       In this case, in particular, realizing that the router's management
    web site exists inside the router might help the user to understand
    where the router's settings are stored.
       If you run a web server on a Windows computer on your desktop, is
    that also not a web site because it's on your desktop, and not someplace
    in the outside world?
       If you enable Remote Management on your router, so that it's
    accessible from the outside world (on the World-Wide Web), does that
    magically transform the router's management not-a-web-site into a
    management web site?
          https://en.wikipedia.org/wiki/Pretzel_Logic
    The title fits.
       I've given up on trying to use logic to persuade you on this point,
    but you might want to avoid trying to confuse innocent bystanders with
    this kind of nonsense.
