naldo29's avatar
naldo29
Minecraft Server not working.
Basically I did the port foward like the video said, udp/tcp and 25565 and i chose my computer and everything but when i send my friend my public ip, it just doesnt work. I know that this is so vague...
  • antinode's avatar
    antinode
    Nov 20, 2020
    > And my internet port ip is 192.168.1.10
       Clearly not your public IP address.  (That's why "usual problem" "1"
    is number 1.)
    > [...] i dont have that much knowledge on it.
       I know almost nothing about it, but a quick Web search for that
    number suggests that it's "smart", which may not be ideal for this
    situation.
          https://dzsi.com/product/znid-gpon-2424a1/
       You might try searching around a little to see if this thing has a
    "bridge" (stupid) mode, which would disable its router functions.  Or if
    it's possible to do all the other stuff on its router, and configure the
    R6700v3 as a WAP.  But the router-ness of that gizmo is the source of
    the port-forwarding trouble when you're using the R6700v3-as-router with
    it.
       Ask your ISP?
