naldo29
Nov 20, 2020Aspirant
Minecraft Server not working.
Basically I did the port foward like the video said, udp/tcp and 25565 and i chose my computer and everything but when i send my friend my public ip, it just doesnt work. I know that this is so vague...
- Nov 20, 2020
> And my internet port ip is 192.168.1.10
Clearly not your public IP address. (That's why "usual problem" "1"
is number 1.)> [...] i dont have that much knowledge on it.
I know almost nothing about it, but a quick Web search for that
number suggests that it's "smart", which may not be ideal for this
situation.https://dzsi.com/product/znid-gpon-2424a1/
You might try searching around a little to see if this thing has a
"bridge" (stupid) mode, which would disable its router functions. Or if
it's possible to do all the other stuff on its router, and configure the
R6700v3 as a WAP. But the router-ness of that gizmo is the source of
the port-forwarding trouble when you're using the R6700v3-as-router with
it.Ask your ISP?
naldo29
Okay so i can send you a picture of it. But thats about as much as i can tell you about it since i dont have that much knowledge on it.
antinode
Nov 20, 2020Guru
is number 1.)
situation.
it.
Ask your ISP?
- naldo29Nov 21, 2020AspirantAlright man, ill try just that, thank you so much for all this info!
