Wheeler1080
Mar 28, 2021Aspirant
Minecraft Server XR500
I am trying to run a Minecrafte server from my desktop PC connected Hardwired from the XR500 tot he PC. I have followed every video on youtube about setting one up. I can get into it locally but when...
antinode
Mar 28, 2021Guru
> [...] I have followed every video on youtube about setting one up.
Sincere thanks for not including the links.
> First I did CMD and ipconfig to get my local IP address [...]
Where "my" means "my server's"? Did you also fix that address using
ADVANCED > Setup > LAN Setup : Address Reservation, so that your server
wouldn't wander away from your port-forwarding rule?
> [...] I did fone one pages [...]
Thanks for the helpful link. (Less sincere, this time.)
> suggested I make a static IP by going into my control panel, [...]
I'd suggest using (dynamic) Address Reservation, instead of
configuring your server with a static address. Careless use of static
addresses can cause more problems than it solves.
> [...] whatsmyipaddress.com and got my local IP# [...]
And got what, exactly? If you're worried about revealing secrets,
then the top half of the address, "a.b" out of "a.b.c.d", would satisfy
most of my curiosity.
What's the IP address of the router's WAN/Internet interface?
ADVANCED > ADVANCED Home : Internet Port : Internet IP Address
For the usual problems with port forwarding, see:
- Wheeler1080Mar 28, 2021Aspirant
Very sorry for not including links, Im not 100% sure how detailed I needed to be. for the youtube videos there were many and all really the same steps but one I used as it was 100% for the type of version of minecraft I was trying for is this :
the address reservation under tha LAN option in set up to use the static IP I picked which is also listed in the list the router menu shows as well.
As far as what I saw for my local IP when I used the whatsyouripaddress it was 98.5.A.BCD
As for the reason I did the static IP this is the site I followed after I couldnt find anything else different from what I had done already :
www.portforward.com/spectrum/rac2v1
Your last question, " What's the IP address of the router's WAN/Internet interface? ADVANCED > ADVANCED Home : Internet Port : Internet IP Address"
I do not have a path like this for a setting such as this. Ithe only WAN setting I see is under settings, setup, WAN setup and it looks like this :
I thank you for the help and appolgise if I didnt include everything you would require to best assit me in my problem.
ok forgive me if this is a double post as I replied and it doesnt seem to have saved.
There was many youtube videos I used to set up the server and many of them were all really the same steps, however the one I used the most is this one "https://youtu.be/bljisWyxU-8
I do have the server address (local) as set up from the static IP (which I will remove as you mentioned that it causes more problems then it solves) which is also the same one in the list when I set the port forwarding.
as far as my local IP it was 98.5.1**.***
And for your last Q "What's the IP address of the router's WAN/Internet interface? ADVANCED > ADVANCED Home : Internet Port : Internet IP Address" :
I do not have that path to provide you the answer to your question. The only thing with WAN I can find in all my settings and options is under SETTINGS>SETUP>WAN SETUP and it looks like this:
I thank you for lending me assistance in my issues, and I appolgise for not including enough information, I am not 100% how much detail I need to provide.
- antinodeMar 28, 2021Guru
> [...]Sorry. I was thinking of a non-Pro-Gaming model, which is organized
differently. Does Settings> Setup > Internet Setup show the router's
WAN/Internet IP address? Settings > Setup > WAN Setup is too much
fine-print. (And, of course, Netgear no longer includes useful screen
shots in its manuals.)- Wheeler1080Mar 29, 2021Aspirant
Sorry again, I attempted to attach a screen shot to my last post of that page, but it seems it it just a broken image. when I go into the WAN setup the only thing with an IP is something called "Default DMZ Server:" and in there is only lists SOME of my local IP, and doesnt list the last 2 number of the local IP. I assume I need to check that box and add the missing number in manually?
So I checked the box and put in the local IP address 192168.1.14 as its showing now after removing the static IP as suggested. I did put in the local IP (as it is now listed in the router page and changed the IP on the minecraft server config file) in the Address Reservation section as well. I then went to yougetsignal.com and tried my local IP address for port 25565 (what minecraft needs) and it still says the port is closed. I am not sure what else I am missing.
