cltejensen's avatar
cltejensen
Follower
Jan 19, 2016
Misfortune Cookie for AC1900 R7000 with firmware v1.4.4.30
Is the firmware level vulnerable to the Fortune Cookie hack? If so is there a more recent version of the firmware that resolves the issue?
  • I think it's fairly standard for companies to be blind-sided by vulnerability reports from third party researchers, but that's not to say that they don't do their own internal testing as well.
    However, Netgear don't use RomPager, and aren't "on the list" as far as CheckPoint are concerned.
    I'd also keep remote management turned "off" to be safer.
    http://mis.fortunecook.ie/misfortune-cookie-suspected-vulnerable.pdf
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi cltejensen,
    No reports has been forwarded that the router is affected by fortune cookie hack.
    • timmi4sa's avatar
      timmi4sa
      Not sure we understand. You need a third-party report in order to recognize a vulnerability??? Should Netgear security or compliance team be responsible for being proactive about testing the products?
      Looking forward to your reply. Thanks.
      • dvinell's avatar
        dvinell
        Tutor
