hakunamatata202
Apr 20, 2022Tutor
Missed 5Ghz channel all of a sudden for R6700V3
I suddenly am no longer able to see my 5Ghz channel in my list When I initially set it up I had 2.4Ghz and a 5Ggz channels. It had been running fine since I got it (a little bit more than a year), t...
Apr 20, 2022Guru - Experienced User
1. what version of firmware are you on?
2. have tried multiple devices?
3. have you named your 5ghz something separate from the 2.4ghz?
4. Have you tried using a wifi scanner to check it and not just the built in utility?
hakunamatata202
Apr 21, 2022Tutor
Thank you for the reply !
V1.0.4.122_10.0.95
Yes, I have tried it on multiple devices
Yes, I have named it separately.
I tried using a wifi scanner both laptop and phone and it's not showing up too.
- plemansApr 21, 2022Guru - Experienced User
have you tried changing the 5ghz channel?
Or trying a factory reset? (not reboot, but a full reset)
- hakunamatata202Apr 21, 2022Tutor
Yes I have tried changing the 5ghz channel and also tried full reset on the router.
I noticed the router light for 2.4 is on and blinking), the light for 5ghz is on but not blinking/ solid white.
- plemansApr 22, 2022Guru - Experienced User
Usually if its on, its broadcasting. the blinking is when something connected?
Tried checking to see if the "enable ssid broadcast" is checked?
Tried changing firmware (maybe there's a bug/corruption in that version)?
