Chuckm513
Aug 21, 2021Aspirant
Missing 2 and5 g
I am using the A7000 nighthawk with a netgear WN2500RP range extender. I had to do a factory reset on my equipment recently. Now, when I check my available networks, I see the Netgear32 (2.4 G) Ne...
Aug 22, 2021Guru - Experienced User
What router do you have?
And firmware on the router?
A7000 is a wireless usb adapter.
did you setup the WN2500rp using wps or using the installation wizard?
- Chuckm513Aug 24, 2021AspirantThanks for getting back to me! much appreciated!My router is an AC1900 Smart WiFi Nighthawk. Model: R7000The Firmware is version V1.0.11.126and I DID use the WPS to connect the extender to the wireless router.By the way, I was able to get the 5G back on my network choices by changing the "SMART CONNECT" settings.Is there anything else I need to do to maximize my connections?
