Chuckm513
Aug 21, 2021Aspirant
Missing 2 and5 g
I am using the A7000 nighthawk with a netgear WN2500RP range extender. I had to do a factory reset on my equipment recently. Now, when I check my available networks, I see the Netgear32 (2.4 G) Ne...
Aug 22, 2021Guru - Experienced User
What router do you have?
And firmware on the router?
A7000 is a wireless usb adapter.
did you setup the WN2500rp using wps or using the installation wizard?
Chuckm513
Aug 24, 2021Aspirant
Thanks for getting back to me! much appreciated!
My router is an AC1900 Smart WiFi Nighthawk. Model: R7000
The Firmware is version V1.0.11.126
and I DID use the WPS to connect the extender to the wireless router.
By the way, I was able to get the 5G back on my network choices by changing the "SMART CONNECT" settings.
Is there anything else I need to do to maximize my connections?
