GidZyy
Jun 05, 2021Follower
Missing wifi alternatives.
Ok so i don't have any idea what im doing here. Except i know that i need help. So it's simple. I have like 5 different Wi-fi options for an example, NETGEAR02 NETGEAR05-2GEXT NETGEAR08-5G-2.... S...
antinode
Jun 05, 2021Guru
> [...] I have like 5 different Wi-fi options for an example, NETGEAR02
Do you have "like 5", or "actually 5"? An accurate list would be
more informative than an example subset, especially if it's guessed at.
"EXT" suggests the existence of a wireless extender, as well as a
router. The variety of "NETGEARxx" names suggests still more gizmos.
> [...] At the wifi thing in the lower right corner of the screen [...]
You're talking about a Windows desktop?
> [...] I have no idea if its here i should ask for help, [...] Please
> help [...]
Asking is harmless enough, but not coming with even the most basic
information just wastes everyone's time.
I'd suggest that you take a gizmo inventory, and discover at least
the actual model number(s) of all your gizmos. Look for "Model" on the
product labels(s). You might find some other suggestive information on
such labels, too. Following any Ethernet cables which might be
connecting these gizmos could be time well spent, too.
If you power-off/on some particular gizmo, and one or more SSIDs
disappear/reappear in your list of availables, then I'd take that as a
hint as to who's broadcasting those SSIDs. If someone knocked out the
power to some extender which is hiding behind furniture, then I wouldn't
expect anyone here to be able to help much.
When you have a complete list of model numbers, you might take those
data to http://netgear.com/support , put in your (actual) model
number(s), and look for Documentation. Get the User Manual(s) (at
least). Read. Look for the LED descriptions and "Troubleshoot".
