ielliott22's avatar
ielliott22
MK62 - won't connect to the internet
Alright, so I recently upgraded to Fiber optic internet. I currently have the nighthawk AC1900 (R7000) but the walls in my house were killing the signal upstairs. I purchased the MK62 mesh wifi6 syst...
  • plemans's avatar
    Jan 31, 2021
    the gateway is a modem/router combo device.
    having 2 devices on the network in router mode causes a doube nat.
    https://kb.netgear.com/30186/What-is-Double-NAT
    options to fix? (only use 1)
    1. put the gigacenter in modem only/passthrough/bridge mode. Whatever your specific isp calls it
    2. put the netgears ip address into the gigacenters DMZ
    3. Put the netgear in access point mode.
