Retired_Member
Dec 15, 2021MK63-MR/MS-60 Connectivity Issues
Recently picked up a Netgear Nighthawk Mesh WiFi MK63 system and am having a surprisingly hard time connecting the 2nd sattelite. I've spent a good amount of time in here reading about similar issues...
Retired_Member
Dec 15, 2021One MS will connect wirelessly in the same room; the other is sitting right beside it and will not.
I'll try moving them around and see if that makes a difference.
The home is about 2600 sq ft. I'd guess the distance is >30 feet.
Dec 15, 2021Guru - Experienced User
Might try a factory reset on the one MS and try to re-sync it. I'd leave off the working MS for now.
